DSI86 config
DSI 4 lane, A channel,DSI CLKREF 427.7Mhz, RGB888.  DP 2 lane. attached panel datasheet.  3288.新版B116HAN03 V110functional spec_20130726.pdf. could you help suggest a setting?
we use following setting, external 27M refclk, vertical colors, but no display. what wrong for the setting? or what we need to check?`
following is schematic, Auxp and Auxn add 100k pull up and pull down resistor.
jeff
  • Hello Jeff,
        We are reviewing your post and we will give you an update by Tuesday .
    Diego.
  • Hello Jeff,
    Could you send please the configuration file that you are using? you can export the configuration file using the DSI Tuner tool, click on the file dialog and then click "Export File".
    Thanks and Regards,
    Luis.
  •  Hi Luis,
    cusotmer can light the panel using external clk.  now they try to modify DSI clk to 416M. but still cannot light the panel.
    pls change attached file .bmp to .DSI.
    Jeff wang
    pls change .mpg to .DSI
  • I am not sure what extend name can be post.
    8306.AU_OPTRONICS_PANE-jeffL.doc
  • Please zip the file you want to post and then attach the zip file.
    Regards.
