Other Parts Discussed in Thread: TCA9555
Is it OK to connect the PCA/TCA9555 center pad to ground?
Newton,
Page 1 of the datasheet, see the statement directly under the device package outline:
"The exposed center pad, if used, must be connected as a secondary ground or left electrically open."
Also see page 34, as this is the Thermal Pad and important for heat dissipation.
Secondary Ground means it is not intended for current-carrying; the GND pin3 is for that purpose, so connecting the Thermal Pad to the pcb GND plane is acceptable as a means to dissipate heat, but not to be used as a power supply GND path.
