New design using the DS90UH928Q
I am creating a new design using this part.
I will be driving a LCD TFT panel from this IC.
I need to better understand whether I can configure the part via the LVDS path or can I simply use
the more basic configuration supported with resistor strappings.
      You can certainly use the input control pins to configure the 928. If there is a need to change configuration status and override the pin configurations, you may then use I2C register control over the FPD-Link III (LVDS) interface to make those changes.
    Sue
