Other Parts Discussed in Thread: TLK105L
We have designed the board with TLK105L.
We are unable to make this board compatible(link integrity fail) to other Ethernet board.
Our board with TLK105L is failed in link integrity (LED does not glow) with following board/device.
1. Surecom Nway Switch - device used - Realtek RTL8309SC
2. Valiant's TDMOIP - device used Marvell 88E6065B-XX-LAJ1I00
3. Valiant TDMOIP - device used Broadcom BCM5387KFBG and BCM5464RA1KFBG
Our board with TLK105L is success fully(Integrity LED glows) working with following system.
1. Tried with 3 PCs - ok.
2. Surecom Hub EP608 -ok
3. Surecom Switch 5port 10/100 Mbps -ok
What could be probably reason behind the intermittent behaviour of our design.
Please note that we are using the Ethernet transceiver in Default mode.
We are attaching the schematic diagram for your reference.
Please help us out asap as our shipment is stuck up due to this problem.
In past we have used many Ethernet transceiver and switch like. Intel- LXT971, micrel KSZ8995xa etc.
We have never experience this problem with those devices
Anil Sharma
Softech Consultants
Mobile 9818421003
