Other Parts Discussed in Thread: TLK10232
Do you have any information on what the typical current draw would be on the TLK10232 if only channel A was being used? Assuming default swing and Clkout settings.
Ideally, I would like to know the typical draw for each supply in this single-channel use case. The only nominal value I could find in the datasheet was for total power dissipation of 1.6W.
Thanks in advance for your help,
Jonathan Bender
