DP83848K / internal Pull-up , Pull-down resistor value(min/max)
Guru 20090 points
Other Parts Discussed in Thread: TLK105
Could you please let me know the maximum internal pull up/pull down resistance value of PU/PD pins ?
I could find the min/typical values from following URL but there is not max value.
http://e2e.ti.com/support/interface/ethernet/f/903/t/327904.aspx
min:15koOms
typ:20k~35kOhms
Since our customer would like to use external resistor for avoiding the shoot through current by indeterminate logic and reducing the leak current , they need PU/PD resistance(min/max) value.
For example, TLK105 has internal PU/PD resistance(min/max) value in the datasheet P.75.
Please kindly let me know the similar data that you can share with us.
Ryuji Asaka
