Other Parts Discussed in Thread: AM3354, DP83848M
We're using DP83848M on AM3354. When the LAN cable is plugged into the RJ45 port, the DP83848M is able to tell am3354 about this status change. However, the DHCP client doesn't work ! No IP address can be obtained from the DHCP server (just a simple WiFi router). Even I set a static IP address to the ethernet port, ping never succeeds, either !
Can anyone advise the workable registers settings for DP83848M ? We need auto 10/100Mbps LAN connection.
Thanks !
