Other Parts Discussed in Thread: XTR117
The XRT117 is labelled as a 4-20mA current loop conditioner. I would like to ask can I use it as a 4-20mA analog output?
My application will controlled by a MCU, therefore there will be a PWM signal generated from the MCU. This PWM signal will then convert to a 4-20mA analog output. Can I use the XRT117 for this application?
Thank you.
