Other Parts Discussed in Thread: TFP401
I want to connect TFP401 to FPGA and read the Data , and i couldnt found any useful document about how should i read from the chip .
Thanks.
Thanks.
Hi Masoud,
I am moving this post to the consumer and computing interface forum as they support the TFP chips.
The TFP401 is only a de-serializer, so basically you just input a clock signal between 25MHz and 165 MHz and a TMDS stream and you will have the RGB components of the TMDS signal at the same frequency as the input clock.
Regards.
when i watch the signals in chipscope , DE(Data enable) signal gets high both when Vsync is high and low . but i thinks it should get active during Vsync= 0 not both ?
