Other Parts Discussed in Thread: CC2540, TUSB3410, TUSB2077A
Our requirement is we have to take data from 5 USB CDC device (CC2540 ) & send it through UART.
And also suggest me to choose an open-source RTOS for this application .
Hi Kumar,
The TUSB3410 is a Serial to USB converter and can be used for this purpose. Could you specify a bit deeper about your project and bussiness case?
Alexis Cortes.
hi Alexis ,
We are using 5 sensor in our project . All our sensor are made using CC2540 as USB peripheral under CDC class .
This 5 sensor we are connecting with our host controller via TUSB2077A . From this host controller we have to
access the sensor data and send this data over UART to BT module (pan1026 or laird-BTM411 Under evaluation )
.we evaluated Vinculum 2 from ftdi we are looking for alternative controller for vinculum 2 ..
Hi Kumar,
After the detailed description of your project, I can see now that the TUSB3410 is not the appropriate device for your specific implementation. Unfortunately, due to the type of solution you require, I cannot suggest any of the products of our group, since any of them could meet the specific requirements you need. Perhaps there is another group at TI that has the right solution you need. I would recommend you to try and look in other groups of TI (maybe at the Microcontrollers' group, etc.)
Alexis Cortes
