Other Parts Discussed in Thread: HVDA551-Q1, SN65HVDA541-Q1
Hi! All,
Could you support to find p2p compatible with Infineon TLE7250GVIO pls?
Thanks for your support in advance.
Hi! All,
Hi Derick,
We have a couple transceivers that are pin to pin equivalent to the TLE7250GVIO device. The newest device in our portfolio is the HVDA551-Q1.
The only difference that I would like to note is that the TLE device does not have a low power wake-up receiver whereas all of our devices that have standby mode do have low-power wake up receivers. This means that when activity occurs on the bus, the transceiver will notify the micro by pulling the RXD output pin low.
The other device that we have that is pin to pin equivalent is the SN65HVDA541-Q1.
John
