Other Parts Discussed in Thread: LMH0302
I am currently using four LMH0302SQ for serializing data across four different channels. The data is coming from a FPGA on a daughter board through a HSMC connector and then coming to LMH0302.on the main board. The 3G data coming to main board is properly output by all 3 channels except one channel. That channel has a trace legth far compared to others. All the four channels are perfectly fine for HD mode but in 3G mode only one channel is not working fine. I have checked signal strengths on all channels and they are fine (pk-pk 800mV). Kindly request you to provide a solution.
Karthik
