Eye-pattern of Ether PHY
Guru 15520 points
Other Parts Discussed in Thread: TLK105L
I'm beginner about Ether PHY and I have a question about TLK105L.
When starting communication with Link partner, the link will be loss and
sometimes it never linked again.
So, I want to check the eye-pattern of TLK105L.
But I don't know how to get the eye-pattern from TLK105L.
Is there any test mode and test pattern to get the eye-pattern?
best regards,
g.f.
    I assume you want to measure the output signaling in 100Base-T mode.  Is that correct?
    In 100Base-T mode, the device will output scrambled idles by default.  These can be used to evaluate the eye pattern.
    100Base-T mode can be configured by writing 0x2100 to the BMCR (register address 0x00) and writing 0x0 to PHYCR (register address 0x19) bit 15 to disable Auto-MDIX.  Alternately, these values can be configured using resistor straps prior to a power up or a reset.
    Patrick
    Thank you for the reply and the details.
    I understood.
    I will try using scramled idles.
    best regard,
    g.f.
