Other Parts Discussed in Thread: DP83630
We are using DP83630 in our products. And now we found an issue when we connect to a 10BASE-T HUB and always got bad packets (BAD CRC) in MAC. By checking the setting in DP83630, we found that the bit LOOPBACK_10_DIS in 10BTSCR is 0, which means that the 10BT loopback is enabled. After disable this LOOPBACK, no bad packets any more.
Normally, this LOOPBACK should not be enabled by default. My question is whether there is an easy way to disable this LOOPBACK by default? and how?
Thanks.
