Other Parts Discussed in Thread: DS92LV18, DS92LV2412, DS92LV2411
I'm trying to interface a DS92LV18 serdes with a common ethernet SFP-tranceiver (http://www.apacoe.com.tw/datasheet/60/LS38-C3L-Tx-N-V1.1.pdf). In my project i need to extend some commands and contacts over fiber in order to cover longer distances and to reduce the number of cable wires.
By now i managed to get the serdes to work on a copper pair. I can transmit and receive data correctly accross two prototype boards i made.
The problem is that i haven't been able to drive correctly the sfp.
According to the datasheet the SFP drives/receives LVPECL levels, so i arranged a passive AC-coupling circuit as described in your application report (http://www.ti.com/lit/an/scaa059c/scaa059c.pdf).
Is there something i'm missing?
Do you have some alternative optical tranceiver that i could use along with DS92LV18?
