Other Parts Discussed in Thread: LMH0341, DS32EL0124
The http://www.ti.com/lit/ds/symlink/lmh0341.pdf Revision Q datasheet shows that tRD has a typical delay of 12T.
I am aligning an system internal reference to the external SDI signal and need the most accurate delay time through the input components of my system.
I put unscrambled PAL through the lmh0341. The TRS 3FF is visible on each of the output lvds pairs (but jumps around as the lmh0341 tries to lock)
There seems to be about a 24T delay from the TRS on the input to the trs on the output when measured with an oscilloscope.
Is this an error in the datasheet, or does the device behave differently with unscrambled data.
