Other Parts Discussed in Thread: TFP410
Hello, team:
Raytheon asks:
TFP410 has RTFADJ resistor. Maximum ratings list this as 300 ohm to open circuit. Recommended value is 510 +/- 1%(non standard resistor). Is there any documentation indicating the results of changing this value? The 510 value seems to be the required resistor but text indicates this has a range that could be used. Using a 511 1% resistor will put us slightly higher and lower than your min/max values at the corner cases. Need documentation showing this will not be an issue.
Thanks for your help.
Joey Grasty
AFA
Dallas FSO
