Other Parts Discussed in Thread: TS3USB221
Dear Sirs
There was the following question from my customer.
As a USB signal path, you will USB HOST IC → TS3USB221 → shielded wire (about 20cm) → of front board USB terminal.
When it is making board wiring, he is routed decided to pattern width and pattern interval by performing impedance matching of 90Ω.
If you are using a USB SW IC, how you should impedance matching as a route?
Please tell me the impedance of the matching method.
Y.Hasebe
