C6747+TLK105 can not communicate with a laptop by eternet
Other Parts Discussed in Thread: TLK105
appriciate your help!
We use C6747 and TLK105 (hardware),DSP/BIOS5.42 and NDK2.0(Software) for ethernet communiction. The development environment is CCS5.5.The ndk/src/hal/evm6747/eth_c6747/cls_mdio.c (and cls_mdio.h) had been reconstucted for TLK105.However no data transmited to pc and no data received on DSP side. The deep observation are:
1) PHY link is setuped, but no data received on dsp side and pc side;
2) Only one transmit action on dsp is observed in void HwTxInt(void) function in file etherdriver.c;
3) Can not found HwRxInt(void) function (in file etherdriver.c) was trigered;
4) The dsp EMAC reg  RXALIGNCODEERRORS and NETOCTETS is not zero;
5) MDC and MDIO function is normal, and can write and read the PHY reg;
6) The data signal of TXD[1:0] and RXD[1:0] between the MAC and PHY can be observed;
7) The TLK105 pin PFBOUT is 1.56v, the pin RBIAS is 1.22v;
I am newbie for ethernet development, cannot find the reason and resolution.  Please help me.  Thanks a lot!!!
The PHY regs' dump is:
PHY REG BMCR: 1000
PHY REG BMSR: 786d
PHY REG PHYIDR1: 2000
PHY REG PHYIDR2: a211
PHY REG ANAR: 1e1
PHY REG ANLPAR: cc61
PHY REG ANER: f
PHY REG ANNPTR: 2001
PHY REG ANLNPTR: 0
PHY REG CR1: 3801
PHY REG CR2: 104
PHY REG CR3: 0
PHY REG REGCR: 0
PHY REG ADDAR: 0
PHY REG PHYSTS: 17
PHY REG PHYSCR: 108
PHY REG MISR1: 2400
PHY REG MISR2: 2000
PHY REG FCSCR: 0
PHY REG RECR: 0
PHY REG BISCR: 100
PHY REG RCSR: 21
PHY REG PHYCR: 1e
PHY REG 10BTSCR: 0
PHY REG BICSR1: 7d
PHY REG BICSR2: 5ee
PHY REG TXCPSR: 2000
PHY REG PWRBOCR: 0
PHY REG VRCR: 17
The hardware schematic is as follow:
The cls_mdio.c source code is as follow (commented original codes is not removed for comparing conviniently):
 *   Copyright (c) Texas Instruments Inc 2002, 2003, 2004, 2005, 2006
 *   Use of this software is controlled by the terms and conditions found in the
 *   license agreement under which this software has been supplied.
 *   @file  csl_mdio.c
 *   PATH:  \$(CSLPATH)\\src\\mdio
 *   @brief  MDIO CSL Implementation on DSP side
 *  Revision History
 *  25-Aug-03 xxx Modified to introduce ~(100 to 200) ms delay in PHY reset.
 *                Also checks ACK value on reading back PHY reset status
 *  10-Mar-06 xxx Ported to TCI6488
//#include <evmc6747.h>         ///added for UINT32   BY QCW
#include <csl_mdio.h>
#include <stdio.h>
#include "hal_c6747_tlk105cfg.h"
 *  \brief  Tick counts for timeout of each state
 *  Note that NWAYSTART falls through to NWAYWAIT which falls through
 *  to LINKWAIT. The timeout is not reset progressing from one state
 *  to the next, so the system has 5 seconds total to find a link.
extern LOG_Obj    trace;
static Uint32 PhyStateTimeout[] = {
                                2,    /**< PHYSTATE_MDIOINIT   - min-delay  */
                                6,    /**< PHYSTATE_RESET      - 0.5 sec max*/
                                41,   /**< PHYSTATE_NWAYSTART  - 4 seconds  */
                                41,   /**< PHYSTATE_NWAYWAIT   - 4 seconds  */
                                51,   /**< PHYSTATE_LINKWAIT   - 5 seconds  */
                                0     /**< PHYSTATE_LINKED     - no timeout */
static void MDIO_initStateMachine( MDIO_Device *pd );
static Uint32 MDIO_initContinue( MDIO_Device *pd );
/**< Curent selection of MAC                                                */
static Uint32        macsel = RMII;
/**< MDIO/EMAC are clocked by SYSCLK4 on this board(EVM6747) = 300 Mhz / 4  */
#define VBUSCLK                    75
    /* Setup the state machine defaults */
    pd->phyAddr       = 0;                  /* The next PHY to try  */
    pd->phyState      = PHYSTATE_MDIOINIT;  /* PHY State            */
    pd->phyStateTicks = 0;                  /* Ticks elapsed        */
    pd->LinkStatus    = MDIO_LINKSTATUS_NOLINK;
Handle MDIO_open( Uint32 mdioModeFlags )
     * Note: In a multi-instance environment, we'd have to allocate "localDev"
    static MDIO_Device localDev;
    /* Find out what interface we are working with */
    //macsel = CSL_FEXT(DEV_REGS->DEVSTAT, DEV_DEVSTAT_MACSEL);
    /* Get the mode flags from the user - clear our reserved flag */
    localDev.ModeFlags = mdioModeFlags & ~MDIO_MODEFLG_NWAYACTIVE;
    /* Setup the MDIO state machine */
    MDIO_initStateMachine( &localDev );
    /* Enable MDIO and setup divider */
    // 操作DSP MDIO 寄存器,控制使能
    MDIO_REGS->CONTROL = CSL_FMKT(MDIO_CONTROL_ENABLE,YES) |
                         CSL_FMK(MDIO_CONTROL_CLKDIV,VBUSCLK) ;
    /* We're done for now - all the rest is done via MDIO_event() */
    return( &localDev );
void MDIO_close( Handle hMDIO )
    Uint32         ltmp1;
    Uint32           i;
    (void)hMDIO;
     * We really don't care what state anything is in at this point,
     * but to be safe, we'll isolate all the PHY devices.
    ltmp1 = MDIO_REGS->ALIVE;
    for( i=0; ltmp1; i++,ltmp1>>=1 )
        if( ltmp1 & 1 )
        //    PHYREG_write( PHYREG_CONTROL, i, PHYREG_CONTROL_ISOLATE |      //comment
        //                                     PHYREG_CONTROL_POWERDOWN );
            PHYREG_write( PHYREG_MODE_CTR_BMCR, i, PHY_BMCR_ISOLATE_EN |
                                                   PHY_BMCR_IEEE_POWER_DOWN );
            PHYREG_wait();
void MDIO_getStatus( Handle hMDIO, Uint32 *pPhy, Uint32 *pLinkStatus )
    MDIO_Device *pd = (MDIO_Device *)hMDIO;
    if( pPhy )
        *pPhy = pd->phyAddr;
    if( pLinkStatus )
        *pLinkStatus = pd->LinkStatus;
 static Uint32  tick_count=0;
Uint32 MDIO_timerTick( Handle hMDIO )
    Uint16      tmp1,tmp2,tmp1gig = 0, tmp2gig = 0, ack;
    volatile Uint32      ltmp1;
    Uint32        RetVal = MDIO_EVENT_NOCHANGE;
     * If we are linked, we just check to see if we lost link. Otherwise;
     * we keep treking through our state machine.
    if( pd->phyState == PHYSTATE_LINKED )
         * Here we check for a "link-change" status indication or a link
         * down indication.
        ltmp1 = MDIO_REGS->LINKINTRAW & 1;
        MDIO_REGS->LINKINTRAW = ltmp1;
        if( ltmp1 || !(MDIO_REGS->LINK)&(1<<pd->phyAddr) )
             * There has been a change in link (or it is down)
             * If we do not auto-neg, then we just wait for a new link
             * Otherwise, we enter NWAYSTART or NWAYWAIT
            RetVal = MDIO_EVENT_LINKDOWN;
            pd->phyStateTicks = 0;  /* Reset timeout */
            /* If not NWAY, just wait for link */
            if( !(pd->ModeFlags & MDIO_MODEFLG_NWAYACTIVE) )
                pd->phyState = PHYSTATE_LINKWAIT;
            else
                /* Handle NWAY condition */
                /* First see if link is really down */
                //PHYREG_read( PHYREG_STATUS, pd->phyAddr );     //comment
                PHYREG_read( PHYREG_MODE_STATUS_BMSR, pd->phyAddr );
                PHYREG_wait();
                PHYREG_waitResultsAck( tmp1, ack );
                if( !ack )
                    /* No PHY response, maybe it was unplugged */
                    MDIO_initStateMachine( pd );
                //else if( !(tmp1 & PHYREG_STATUS_LINKSTATUS) )       //comment
                else if( !(tmp1 & PHY_BMSR_LINK_VALID) )
                    /* No Link - restart NWAY */
                    pd->phyState = PHYSTATE_NWAYSTART;
                                  PHYREG_write( PHYREG_CONTROL, pd->phyAddr,
                                  PHYREG_CONTROL_AUTONEGEN |
                                  PHYREG_CONTROL_AUTORESTART );
                                  */   //comment
                    PHYREG_write( PHYREG_MODE_CTR_BMCR, pd->phyAddr,
                                  PHY_BMCR_AUTO_NEG_EN |
                                  PHY_BMCR_RESTART_AUTO_NEG_EN );
                    PHYREG_wait();
                else
                    /* We have a Link - re-read NWAY params  */
                    pd->phyState = PHYSTATE_NWAYWAIT;
     * If running in a non-linked state, execute the next
     * state of the state machine.
    if( pd->phyState != PHYSTATE_LINKED )
        /* Bump the time counter */
        pd->phyStateTicks++;
        /* Process differently based on state */
        switch( pd->phyState )
        case PHYSTATE_RESET:
            /* Don't try to read reset status for the first 100 to 200 ms */
            if( pd->phyStateTicks < 2 )
                break;
            /* See if the PHY has come out of reset */
            //PHYREG_read( PHYREG_CONTROL, pd->phyAddr );         //comment
            PHYREG_read( PHYREG_MODE_CTR_BMCR, pd->phyAddr );
            //if( ack && !(tmp1 & PHYREG_CONTROL_RESET) )     //comment
            if( ack && !(tmp1 & PHY_BMCR_RESET) )
                /* PHY is not reset. If the PHY init is going well, break out */
                if( MDIO_initContinue( pd ) )
                    break;
                /* Else, this PHY is toast. Manually trigger a timeout */
                pd->phyStateTicks = PhyStateTimeout[pd->phyState];
            /* Fall through to timeout check */
        case PHYSTATE_MDIOINIT:
CheckTimeout:
            /* Here we just check timeout and try to find a PHY */
            if( pd->phyStateTicks >= PhyStateTimeout[pd->phyState] )
                // Try the next PHY if anything but a MDIOINIT condition
                if( pd->phyState != PHYSTATE_MDIOINIT )
                    if( ++pd->phyAddr == 32 )
                        pd->phyAddr = 0;
                for( tmp1=0; tmp1<32; tmp1++ )
                    if( ltmp1 & (1<<pd->phyAddr) )
                        if( MDIO_initPHY( pd, pd->phyAddr ) )
                            break;
                        pd->phyAddr = 0;
                // If we didn't find a PHY, try again
                if( tmp1 == 32 )
                    pd->phyAddr       = 0;
                    RetVal = MDIO_EVENT_PHYERROR;
            break;
        case PHYSTATE_NWAYSTART:
             * Here we started NWAY. We check to see if NWAY is done.
             * If not done and timeout occured, we find another PHY.
            /* Read the CONTROL reg to verify "restart" is not set */
            //PHYREG_read( PHYREG_CONTROL, pd->phyAddr );    // comment
            if( !ack )
                break;
            //if( tmp1 & PHYREG_CONTROL_AUTORESTART )            //comment
            if( tmp1 & PHY_BMCR_RESTART_AUTO_NEG_EN )
                goto CheckTimeout;
            /* Flush latched "link status" from the STATUS reg */
            PHYREG_wait();
            /* Fallthrough */
        case PHYSTATE_NWAYWAIT:
             * Here we are waiting for NWAY to complete.
            /* Read the STATUS reg to check for "complete" */
            PHYREG_waitResultsAck( tmp1, ack );                        //tmp1=30829
            if( !ack )
                break;
            //if( !(tmp1 & PHYREG_STATUS_AUTOCOMPLETE) )      //comment
            if( !(tmp1 & PHY_BMSR_AUTO_NEG_COMPLETE) )
                goto CheckTimeout;
            //PHYREG_read( PHYREG_ADVERTISE, pd->phyAddr );     //comment
            PHYREG_read( PHYREG_AUTO_NEG_ANAR, pd->phyAddr );
            PHYREG_waitResults( tmp1 );
            //PHYREG_read( PHYREG_PARTNER, pd->phyAddr );       // comment
            PHYREG_read( PHYREG_AUTO_NEG_PARTNER_ANLPAR, pd->phyAddr );
            PHYREG_waitResults( tmp2 );
             * Use the "best" results
            tmp2 &= tmp1;
            /* Check first for 1 Gigabit */
            //if( (tmp1gig & PHYREG_ADVERTISE_FD1000) && (tmp2gig & PHYREG_PARTNER_FD1000) )
            //    pd->PendingStatus = MDIO_LINKSTATUS_FD1000;
            //else if( tmp2 & PHYREG_ADVERTISE_FD100 )            //comment , no support Gigabit
            //if( tmp2 & PHYREG_ADVERTISE_FD100 )                  //comment
            if( tmp2 & PHY_ANAR_100TXFD )
                pd->PendingStatus = MDIO_LINKSTATUS_FD100;
            //else if( tmp2 & PHYREG_ADVERTISE_HD100 )            //comment
            else if( tmp2 & PHY_ANAR_100TX )
                pd->PendingStatus = MDIO_LINKSTATUS_HD100;
            //else if( tmp2 & PHYREG_ADVERTISE_FD10 )             //comment
            else if( tmp2 & PHY_ANAR_10TFD )
                pd->PendingStatus = MDIO_LINKSTATUS_FD10;
            //else if( tmp2 & PHYREG_ADVERTISE_HD10 )             //comment
            else if( tmp2 & PHY_ANAR_10T )
                pd->PendingStatus = MDIO_LINKSTATUS_HD10;
             * If we get here the negotiation failed
             * We just use HD 100 or 10 - the best we think we can do
            //else if( tmp1 & PHYREG_ADVERTISE_HD100 )          //comment
            else if( tmp1 & PHY_ANAR_100TX )
            else
            /* Fallthrough */
        case PHYSTATE_LINKWAIT:
             * Here we are waiting for LINK
            /* Read the STATUS reg to check for "link" */
            if( !ack )
                break;
            //if( !(tmp1 & PHYREG_STATUS_LINKSTATUS) )      //comment
                goto CheckTimeout;
            /* Make sure we're linked in the MDIO module as well */
            ltmp1 = MDIO_REGS->LINK;
            if( !(ltmp1&(1<<pd->phyAddr)) )
                goto CheckTimeout;
            /* Start monitoring this PHY */
            MDIO_REGS->USERPHYSEL0 = pd->phyAddr;
            /* Clear the link change flag so we can detect a "re-link" later */
            MDIO_REGS->LINKINTRAW = 1;
            /* Setup our linked state */
            pd->phyState   = PHYSTATE_LINKED;
            pd->LinkStatus = pd->PendingStatus;
            RetVal = MDIO_EVENT_LINKUP;
            break;
    return( RetVal );
Uint32 MDIO_initPHY( Handle hMDIO, volatile Uint32 phyAddr )
    Uint32      ltmp1;
    Uint32      i,ack;
    /* Switch the PHY */
    pd->phyAddr = phyAddr;
    /* There will be no link when we're done with this PHY */
    /* Shutdown all other PHYs */
    #if 0
    ltmp1 = MDIO_REGS->ALIVE ;
        if( (ltmp1 & 1) && (i != phyAddr) )
            PHYREG_wait();
   #endif
    /* Reset the PHY we plan to use */
    //PHYREG_write( PHYREG_CONTROL, phyAddr, PHYREG_CONTROL_RESET );        //comment
    PHYREG_write( PHYREG_MODE_CTR_BMCR, phyAddr, PHY_BMCR_RESET );
    PHYREG_waitResultsAck( i, ack );
    /* If the PHY did not ACK the write, return zero */
    if( !ack )
        return(0);
    /* Setup for our next state */
    pd->phyState = PHYSTATE_RESET;
    return(1);
    Uint16      tmp1,tmp2;
    Uint16      tmp1gig = 0;
        static Uint16 StatusRegister[32];
        int    index = 0;
        for (index =0; index < 32; index++)
            StatusRegister [index] = 0xDEAD;
        /* Now we read the status register */
        for (index =0; index < 32;index++)
                //PHYREG_read( PHYREG_STATUS, index );           // comment
                PHYREG_read( PHYREG_MODE_STATUS_BMSR, index );
            /* Copy the Status value into the Status. */
            StatusRegister [index] = tmp1;
    /* Read the STATUS reg to check autonegotiation capability */
    if ( (macsel == GMII) || (macsel == RGMII) )    //  macsel = RMII;
        //PHYREG_read( PHYREG_EXTSTATUS, pd->phyAddr );
        PHYREG_read( PHYREG_STATUS_PHYSTS, pd->phyAddr );
        PHYREG_waitResults( tmp1gig );
    /* See if we auto-neg or not */
    if( (pd->ModeFlags & MDIO_MODEFLG_AUTONEG) &&  (tmp1 & PHY_BMSR_AUTO_NEG_ABLE) )
                                    // (tmp1 & PHYREG_STATUS_AUTOCAPABLE) )
        /* We will use NWAY */
        /* Advertise 1000 for supported interfaces */
            tmp1gig >>= 4;
            tmp1gig &= PHYREG_ADVERTISE_FD1000;
            PHYREG_write( PHYREG_1000CONTROL, pd->phyAddr, tmp1gig );
        */                                                    //comment, no Gigabit
        /* Shift down the capability bits */
        tmp1 >>= 6;               //
        /* Mask with the capabilities */
              tmp1 &= ( PHYREG_ADVERTISE_FD100 | PHYREG_ADVERTISE_HD100 |
                  PHYREG_ADVERTISE_FD10 | PHYREG_ADVERTISE_HD10 );
                */                                                      //comment
        tmp1 &= ( PHY_ANAR_100TXFD | PHY_ANAR_100TX |
                  PHY_ANAR_10TFD | PHY_ANAR_10T );
        /* Set Ethernet message bit */
        //tmp1 |= PHYREG_ADVERTISE_MSG;                   //comment , protocol selection
         tmp1 |= PHY_PROTOCOL_SEL_8023U;
        /* Write out advertisement */
        //PHYREG_write( PHYREG_ADVERTISE, pd->phyAddr, tmp1 );          // comment
        PHYREG_write( PHYREG_AUTO_NEG_ANAR, pd->phyAddr, tmp1 );
        PHYREG_wait();
        /* Start NWAY */
        //PHYREG_write( PHYREG_CONTROL, pd->phyAddr, PHYREG_CONTROL_AUTONEGEN );  //comment
        PHYREG_write( PHYREG_MODE_CTR_BMCR, pd->phyAddr, PHY_BMCR_AUTO_NEG_EN );
        PHYREG_wait();
        // added by qcw
        PHYREG_write( PHYREG_MODE_CTR_BMCR, pd->phyAddr, PHY_BMCR_SPEED_SEL_100 );
        PHYREG_wait();
        PHYREG_write( PHYREG_MODE_CTR_BMCR, pd->phyAddr, PHY_BMCR_DUPLEX_MODE );
        PHYREG_wait();
        PHYREG_write(PHYREG_BIST_CTRL_BICSR1,pd->phyAddr,0x5dcu);
        PHYREG_wait();
        //end adding
        //              PHYREG_CONTROL_AUTONEGEN|PHYREG_CONTROL_AUTORESTART );
                      PHY_BMCR_AUTO_NEG_EN|PHY_BMCR_RESTART_AUTO_NEG_EN);
        PHYREG_wait();
        /* Setup current state */
        pd->ModeFlags |= MDIO_MODEFLG_NWAYACTIVE;
    else
        /* We will use a fixed configuration */
        tmp1 >>= 10;
        /* Mask with possible modes */
        tmp1 &= ( MDIO_MODEFLG_HD10 | MDIO_MODEFLG_FD10 |
                  MDIO_MODEFLG_HD100 | MDIO_MODEFLG_FD100 );
            tmp1gig >>= 8;
            tmp1gig&= MDIO_MODEFLG_FD1000;
            /* Mask with what the User wants to allow */
            tmp1gig &= pd->ModeFlags;
        tmp1 &= pd->ModeFlags;
        /* If nothing if left, move on */
        if( (!tmp1) && (!tmp1gig) )
            return(0);
        /* Setup Control word and pending status */
        if( tmp1gig ) {
                tmp2 = PHYREG_CONTROL_SPEEDMSB | PHYREG_CONTROL_DUPLEXFULL;
              else */                                               //comment , no Gigabyte
        if( tmp1 & MDIO_MODEFLG_FD100 )
            //tmp2 = PHYREG_CONTROL_SPEEDLSB | PHYREG_CONTROL_DUPLEXFULL;//comment
            tmp2 = PHY_BMCR_SPEED_SEL_100 | PHY_BMCR_DUPLEX_MODE;
        else if( tmp1 & MDIO_MODEFLG_HD100 )
            //tmp2 = PHYREG_CONTROL_SPEEDLSB;                                 //comment by qcw
            tmp2 = PHY_BMCR_SPEED_SEL_100;
        else if( tmp1 & MDIO_MODEFLG_FD10 )
            //tmp2 = PHYREG_CONTROL_DUPLEXFULL;                         //comment
            tmp2 = PHY_BMCR_DUPLEX_MODE;
        else
            tmp2 = 0;
        /* Add in internal phy loopback if user wanted it */
        if( pd->ModeFlags & MDIO_MODEFLG_LOOPBACK )
            //tmp2 |= PHYREG_CONTROL_LOOPBACK;                 //comment
            tmp2 |= PHY_BMCR_MII_LOOPBACK_EN;
        /* Configure PHY */
        //PHYREG_write( PHYREG_CONTROL, pd->phyAddr, tmp2 );     //comment
        PHYREG_write( PHYREG_MODE_CTR_BMCR, pd->phyAddr, tmp2 );
        PHYREG_wait();
        /* Add in external phy loopback with plug if user wanted it */
        if( pd->ModeFlags & MDIO_MODEFLG_EXTLOOPBACK ) {
            PHYREG_write( PHYREG_SHADOW, pd->phyAddr, PHYREG_SHADOW_EXTLOOPBACK );
            PHYREG_wait();
             */                                                   //comment, no shadow
        pd->ModeFlags &= ~MDIO_MODEFLG_NWAYACTIVE;
    return(1);
Uint32 MDIO_phyRegRead( volatile Uint32 phyIdx, volatile Uint32 phyReg, Uint16 *pData )
    Uint32 data,ack;
    PHYREG_read( phyReg, phyIdx );
    PHYREG_waitResultsAck( data, ack );
    if( !ack )
        return(0);
    if( pData )
        *pData = data;
    return(1);
Uint32 MDIO_phyRegWrite( volatile Uint32 phyIdx, volatile Uint32 phyReg, Uint16 data )
    Uint32 ack;
    PHYREG_write( phyReg, phyIdx, data );
    if( !ack )
        return(0);
    return(1);
  • Hi CW,
    Since you are operating in RMII mode, It might help to know what sort of packet sizes you are transmitting. For more tolerance you can increase the buffer size of the FIFO by accessing the RCSR (0x0017) register. Bits [1:0] allow you to adjust the tolerance (please see page 68 in the datasheet).
    Since you have already measured the key voltages and have indicated to me you see link (confirmed by register 1 as well), I think another option would be to make a loopback cable. What this will do is allow you to see if what you are sending out matched what you receive.
    Ross
  • Hi, Ross
    Thanks a lot for your reply!!
    I had checked the codes. The packet size was defined as 1514 in etherdriver.c as follow:
            ecfg.UseMdio            = 1;
    	ecfg.CoreNum           = 1;
    	ecfg.PktMTU             = 1514;
    	ecfg.TotalNumOfMacAddrs = 1;
    	ecfg.DescBase           = EMAC_DESC_BASE_CPPI;
    	PktMTU                  = ecfg.PktMTU;
    I had tried to define the TLK105 REG RCSR as follow:
           PHYREG_write( PHYREG_RMII_CTRL_STATUS_RCSR, pd->phyAddr, 0X22u );    // ELAST_BUF: 10 = 6 bit tolerance (up to 7200 byte packets)
           PHYREG_wait();
    The error is still exist. At same time, I found a strange sigal sequence, following is the screenshot:
    I can not find out the reason why the RXER signal time sequence is same at all to the RXD1. Can you give me some suggestions.
    best regards
    Qiu
  • Hi Qiu,
    Please continue this thread on the other post.
    Ross
