Other Parts Discussed in Thread: DP83848K
Hi
I am interest on your chip part “ DP83848K “ (Ethernet Phy) to use in our medical application project. Before start using in our project, I have some technical queries regarding chip which is listed below please clarify us
DP83848K support CAP to CAP topology (magnetic-less coupling) ?
In CAP to CAP topology how much length we can run the cable between two PHY (In our case one PHY + CAP in one board and second PHY + CAP in another board – both will connect through four connectors + cable)?
If DP83848K (PHY) put in CAP to CAP topology in that case whether DP83848K (PHY) will support auto-negotiation or not?
Have you did any compliance testing for you DP83848K (chipset) at CAP to CAP topology or not.
You have SW driver support for DP83848K?
Sathiyan
