Hi Team,
Could you please tell us the functional difference between TLK10232 and TLK10034 ?
Our customer is considering to use TLK10034 instead of two TLK10232, as TLK10034 is quad channel and TLK10232 is dual channel transceiver. As TLK10232 is a newer device, I believe it has some advantages compared to TLK10034. If customer chose TLK10034 rather than TLK10232, what would be the main difference which would not be able to achieve ?
Addition to the above question, which solution would you recommend ? Could you please give us your opinion.
Thanks in advance.
Kawai
