Other Parts Discussed in Thread: XIO2001
Hi
Does XIO2001 need EEPROM?
Best regards.
When there is no EEPROM, the XIO2001 uses the default values for all its configuration registers.
You need an EEPROM only if you actually want to configure some settings with non-default values.
Section 8.3.8.1 of the datasheet says:
If no external EEPROM is required, then the serial-bus interface is permanently disabled by attaching a pulldown resistor to the SCL signal.
