Other Parts Discussed in Thread: TPD12S521
Is there any particular reason 47K ohm pull-up resistors are shown on the DCLK_IN and DDAT_IN lines? Shouldn't these typically be around 1.7K ohms (depending on the I2C driver)?
Hi Michael,
That's correct, if you already have pull-ups don't use more as long as you have 47k or less already. If you have, say 100k internal, you should put 89k pull-ups as shown in the data sheet where the 47k are. This would give 47k from 100k||89k.
