Other Parts Discussed in Thread: LMH0387
Two questions:
How critical are the 1uF and 220 ohm values on the TERM_RX pin?
The dc level on the BNC_IO pin is 3.3V (same as the supply rail). Is this what I should expect?
Two questions:
Hi Dave,
This is OK. The LMH0387 has the integrated return loss network and pull up termination inside the package. You are just measuring this high speed node from a DC perspective and seeing the node pulled up to VCC through the pull up termination.
Keep in mind that a high speed signal will view this node as having the return loss network plus the termination to an AC ground.
Mike Wolfe
DPS APPS / SVA
