ONET1151M Functionality with Hardware Configuration Settings or Onboard EEPROM
I wanted to know if there is another product similar in the specifications to the ONET1151M.  However, rather than programming volatile registers through a digital two wire interface, is there a similar device that uses pin configurations?  If not, is there on board non-volatile memory that can store digitally programmed configuration settings?  Thank-you!
P.S. The device that motivated this question was the ADN2526 by ADI.
