Other Parts Discussed in Thread: TPS65982
Hello USB Team,
I have a question to the ILDO_3V3EX specification within the datasheet:
On datasheet page 9, we are specifying the parameter ‘ILDO_3V3EX’.
What does this parameter specify and under which test conditions (is this the current available for external loads?)?
The reason is, that my customer thinks this is the externally provided current from LDO_3V3, which under the specified numbers (5mA max) is never enough to supply an Winbond/Spansion Flash chip und read/write conditions.
So can you clarify how much current is maximum available on the LDO_3V3 for external loads, please?
Albert
