SN65LVPE512 and SN65LVPE502A/B
Guru 29720 points
Other Parts Discussed in Thread: SN65LVPE512, SN65LVPE502A, TUSB551, TUSB501
Hi Team,
Which do you recommend SN65LVPE512 or SN65LVPE502A/B for customer's new project?
It seems SN65LVPE512 is newer one.
Could you also tell me the difference between SN65LVPE512 and SN65LVPE502A/B?
Yaita / Japan disty
  • Hello Yaita-san,
       We recommend to use the SN65LVPE512 since it has all the SN65LVPE502A improvements plus:
    • Fixes LFPS compliance test failures when de-emphasis is added observed in LVPE502A.
    • De-emphasis and OS levels changed.
    Please let me know if the customer's implementation is Host side or device side, If the customer is willing to use the re-driver on a device implementation, then I recommend to use the SN65LVPE502B, and for movil applications the best options is the TUSB551 or the TUSB501.
    Diego.
  • Hi Diego-san,
    Thank you for your support.
    My customer's application is note PC(Host side).
    I understood SN65LVPE512 is recommended for dual channel requirement.
    Yaita
