Other Parts Discussed in Thread: DP83848C
I am looking to integrate this part into my design. The pinout table in the march 2015 datasheet calls for a pin 49 for GNDPAD.
This consistent with the Pin Layout Diagram in Section 4.1 and the Package Pin Assignments table in section 4.2 for the extended and extreme temp versions of this device. The pin layout diagram is shown for the HLQFP package only.
Since I am targeting a commercial temp part, I should be referencing the PT drawing (S-PQFP-G48) at the end of the datasheet. This drawing does NOT show a ground pad connection, but the Package Pin Assignments table in section 4.2 shows a GNDPAD @ pin 49.
So is there a GNDPAD connection on the PQFP or not?TI DP83848x DATASHEET 25-SEP-2015.pdf
The datasheet that I am referencing is attached.
Mazen
