Differential driver for an Opto-isolator
Other Parts Discussed in Thread: AM26LV31E
hello,
i want to control an drive amplifier.
i ve made an pcb with an 26LS31 but the ic doesnt work because the amplifier input is opto isolated. sadly i noticed this too late.
i attached the drive ampifier input circuit.
My Question:
Have ti an ic with the same pinout but differential ttl signal?
Which ic is the right one?
thx a lot
  • Tee,
    If you positively need a pin to pin compatible device then try AM26LV31E
    It is designed for 3.3V operation therefore running at 5V should increase the output voltage by about 1.7V
    I have no data for running at the elevated voltage other than the absolute maximum voltage is 6V in the data sheet.
    What are you doing with the other three channels?
  • Tee,
    The 26LS31 has differential TTL outputs.  You should look at the output waveform and verify it is working as you intended.  There may be nothing wrong with the schematic.
    Lee
