Simplified Buttons (up to 24)
Other Parts Discussed in Thread: TCA8418, TCA8418E
Hi team,
I'm having a difficult time understanding the TCA8418's datasheet.
On Page 29, the keypad arrangement is shown without resistors.  I am confused about how the pins are configured as outputs and I don't know if there are limitations.
What are the recommended row/column interface?
I require a simplified button interface of up to 24.
Thank you,
Mauricio Solis
  • Hello Mauricio,
    Thanks for your question.
    First off, is there a reason you're looking at the TCA8418 instead of the TCA8418E?
    I would recommend you look at the TCA8418E, since it has higher ESD protection rating and also has the erratas fixed from the TCA8418.
    Another bonus is that datasheet update that I just finished is online for the TCA8418E (and soon the non-E as well), where I tried to be very clear about the features of the device.
    The way the keypad works, is that the rows are configured as inputs with internal pull-up resistors enabled (keep in mind that the device features internal pull-up resistors), and the columns are configured as outputs, driven low. When a button is pressed, it will short a row and column together, and the input will see a falling transition, letting the device know to start searching for a key press.
    Are your 24 buttons to be multiplexed? I assume you are planning on doing a multiplexed keypad
