TPS65982 EVM code support
Other Parts Discussed in Thread: TPS65982-EVM, TPS65982
Hi Tean
          Could you help to prvoide TPS65982EVM SPI flash data by json or ctb file by TI web tools? [ TPS6598X_WebTool_vs.04 ]
          TI EVM can test pass for PD function , we want use this code and Modify Display port function.
          another question : EVM have Dip swtich for change mode , How to do TI wdb tools to setting function?
  • Hi Kerr,
    Thank you for your question.
    The TPS65982-EVM FW located in the web tool is a special binary file. Due to the nature of the dip switches, reloading new app code everytime the dip switch is changed to a different configuration, there is no json or ctb file for this binary file. Additionally, the TI web tools do not have a setting to implement the "dip switch for change mode." We will update the TPS6598x Configuration Tool User Guide to explain this file.
    Please use one of the default configurations for the TPS65982 or TPS65986 and modify as necessary to enable your DP functionality.
    Karl
