TPS65982 change the power source issue.
Other Parts Discussed in Thread: TPS65982, TPS6598X-CONFIG
Hi Sir,
Our customer application the TPS65982 have some issue as below. May I have your suggest to close this issue?
When TPS65982 is "Charger mode" we cut the AC source power supply, the TPS65982 will change to "Dead battery mode" power source is from PC side.
If we plug in the AC source again, but TPS65982 can't return to charge mode.
AC ( charge mode)  --> PC mode  --> AC power supply ( can't return to charge mode)
We are suggest the reset USB or reset TPS65982, But that's not best solution for our customer. because maybe the Hub is Data transmission.
Maybe add one MUC to controll is good solution,
Do you have any suggest for MCU PN? or TI have similar function FW can be share to our customer?or any Hardware schematic can be switch this mode?
