TUSB3410 USB I2C Header Generator Utility
Other Parts Discussed in Thread: TUSB3410
i can't find the TUSB3410 USB I2C Header Generator Utility  please can  you provide me with a link.
  • Hello Ahmed,
    The I2C Header Generator is no more recommended to be used instead of this one please use the TUSB3x10 EEPROM  Burner tool (http://www.ti.com/lit/zip/sllc443)
    Roberto.
  • Hi Roberto,
    I am writing firmware for TUSB3410. Using SDCC I've generated .ihx file then using GCC I created a bin file. To load the firmware to EEPROM I am using EEPROM burner utility.
    The Descriptor defined in firmware is different from descriptor given on EEPROM burner utility. How can I modify the descriptor for EEPROM Header using EEPROM Burner. Only VID, PID, Manufacturer and Product name can be changed using EEPROM burner utility.
    Kindly help me for same.
    Thanks and Regards
    Kshitij Gupta
