TDMS442 I2c
Other Parts Discussed in Thread: TMDS442
I have an app with 1 source and 2 simultaneous sinks.
Each sink will have I2C components unrelated to the HDMI port.
Can I connect the source to the sources I2C port, then communicate with both sink ports using the TMDS442 I2C sink ports as pass through?
Steve
  • Hi Steve,
    Are you trying to use TMDS442 as an I²C switch?
    Is this unrelated to HDMI?
    If that is the case, you can do it, you just need to apply assert 5V_PWR in source ports, and select desired source port using SA/SB and SP for sink port.
    However you cant have the same signal form source port in both sink ports, you have to choose one.
