Common mode signal for DS3486
Other Parts Discussed in Thread: DS3486
i intend to use DS3486 as a common mode receiver for 24V signal ("High"=24V, "Low"=0V)
In the datasheet I cannot find any thresholds for common mode signal.
Would this part work with common mode signal like that?
Many thanks in advance.
  • Hi Vitali,
    A 24V "High" and 0V "Low" suggest a typical common mode voltage of 12V.  The DS3486 has a recommended input common mode voltage range of +/- 7V.  The signal you describe falls outside this range.
    The DS96F175 is a similar device with a input common mode voltage range that extends to +12V.
    Lee
