Other Parts Discussed in Thread: SN74CB3Q3384A, TCA9548A
Hi team,
1 My customer uses SN74CB3Q3384A to translate 5V to 3.3V I2C bus. I am not sure of it. It seems to work properly...Could you please kindly check?
2 I can only see a MOSFET inside and connect the A and B port. and Rdson is small to 3-8ohm. How can a MOSFET translate 5V to 3.3V logic, which is what I don't know clearly. Could you help kindly show me the theory? From what I know, Vax=Vbx, if it is really a MOSFET.
3 My customer uses TCA9548, too. In datasheet, it can translate 5V to 3.3V from 5V-master to 3.3V slave. My customer's situation is master is 3.3V, slaves are 5V and 3.3V. Is that OK and have no risk? I also don't know how this part translate, could you please kindly explain it? (it also has only FET inside...)
Best Regards
Michael
FAE
