SN65HVD233 and CAN2.0B
Other Parts Discussed in Thread: SN65HVD233
I am inquiring about a component, specifically the SN65HVD233. This part looks ideal for my application but I am curious if this is compliant with CAN2.0B as it does not state in the datasheet.
Thank you,
  • Hi Roman,
    The CAN2.0B specification actually doesn't include the physical layer characteristics that would be relevant for a transceiver chip like SN65HVD233. It relates more to the CAN protocol/data link layer. The physical layer (i.e., properties of the actual electrical signals on the bus sent and received by a transceiver chip) are defined in ISO 11898-2, which is referenced in the SN65HVD233 datasheet. The device could be used with a CAN2.0B-compliant controller, though.
    Max
  • Thank you for the answer, this was very helpful.
    Roman
