DS25CP114 - Simulation Model
Guru 19785 points
Other Parts Discussed in Thread: DS25CP114, DS25CP104A
Hello Team,
Is there a simulation model, IBIS-AMI or SPICE model, which could be used for DS25CP114 ?
Kawai
  • Hi Kawai,
    Is there one SVA-SDS NDA in place?
    We do have the DS25CP104A's IBIS-AMI model, we can use this model.
    Here is the difference between DS25CP104A and DS25CP114.
    On the DS25CP104A each differential input and output is internally terminated with a 100Ω resistor to lower return losses, reduce component count and further minimize board space. For added design flexibility the 100Ω input terminations on the DS25CP114 have been eliminated. This enables a designer to build custom crosspoint configurations and distribution circuits that require a limited multidrop signaling topology
    Please check with TI local sales on the NDA.
    Liang
  • Hello Liang-san,
    Thank you for the information. I understood that IBIS-AMI Model is not prepared for DS25CP114 and the only difference is the input 100 Ohm termination.
    Kawai
