Other Parts Discussed in Thread: AM26LV31E, TS5A21366
Hi all,
Would you mind if we ask AM26LVE31?
Please refer to the following attachment file.
20151224_AM26LV31E.pdf
If you have some comment, could you let us know?
Kind regards,
Hirotaka Matsumoto
Hi all,
Kind regards,
Hirotaka Matsumoto
Ron san,
Thank you for your very kind reply!
And we apologize that we are late for the reply.
Why is this dual purpose needed?
->We heard that our customer would like to reduce the connector.
In transmit mode what is the data rate and is the cable terminated correctly?
->We don't know the data rate and the cable terminated. However, they use only two ways Hi-z or sending.
In receive mode what is the data rate and the cable length?
->We don't know the data rate and the cable length.
So, we ask our customer followings;
-(In receive mode) the data rate and the cable length
-(In transmit mode) the data rate and the cable terminated
Kind regards,
Hirotaka Matsumoto
Ron san
We are sorry that our explanation is not enough.
In our customer schematic, they use only Pattern1 or Pattern2.
(So, they don't switch from Pattern X to Pattern X in operation. Please refer to an attachment file.)
20160106_AM26LV31E.pdf
And then, we heard from our customer as followings;
->In tansmit mode(Pattern1), AM26LV31E is enable,
- the cable length : less than 1m
- the data rate : less than 32MHz, so minimum pulse width is 40ns, maximum pulse width is 2.5us.
- the cable terminated : Of course, yes.
So, in case of the cable length 1m, is it(AM26LV31E) possible to transmit the data with 40ns?
->In receive mode(Pattern2), AM26LV31E is disable and Hi-z,
- the cable length : less than 200mm~300mm
- the data rate : JTAG signal(XXMHz)
- Switch device : They will use TS5A21366
Kind regards,
Hirotaka Matsumoto
Ron san,
We are sorry to rush you.
Kind regards,
Hirotaka Matsumoto
Ron san
Thank you for your reply during a busy time always!
OK, we recommend that our customer should use ESD protection device.
Kind regards,
Hirotaka Matsumoto
