Other Parts Discussed in Thread: PCA9546A
My customer use PCA9546A to do a I2C bus switch, and the channel will be disabled when the channel is non-used after 1s.
Customer used the same control code to the other factory IC, and won't happen this issue. Please help to clarify it. Thanks.
Below picture shows, they switching the PCA9546A to enalbe ch2. (G2_SDA/SCL: input, Riser2_SDA/SCL: ouput, and Mux addr: 0xE0)
After 1s, there is no input data changed but output data will pull low 2s. And the channel will be disabled.
Schematic
