Other Parts Discussed in Thread: TCA9517A, TCA4311A, P82B96, P82B715
I'm designing a communication I2c system from board to board connected via cable.
Each system has a different power supply (with common ground), that power-up at different time; I intend to use on each side a TCA4311A or a TCA9517A that became connected in series.
Which part do you think is better for my problem?
Also consider that in my system I can't connect the enable pin at the same command, but each board drive it from themself.
Could you give me any suggestion?
