Other Parts Discussed in Thread: TPS65982, TPS65982-EVM
I am using a TPS65982 in a new design. I want to activate an output when a cable is connected.
There is an event called "ATTACHED_L_EVENT" which activates an output when a cable is plugged.
But in the document slvuai9a the output is set to high for a plugged cable, in the document slvuah7a the output is set to low. What is the right configuration?
