Other Parts Discussed in Thread: DS50PCI402
Our customer uses the DS50PCI402 with SMBus Mode, has question.
When the customer write a register, how should he bias for nPRSNT pin?
Is it High or Low or either?
Naoki Aoyama
Naoki Aoyama
Hi Naoki,
I prefer to bias the nPRSNT pin "Low" on the external pin. This gives normal operation of the DS50PCI402. If there is some system or application condition which requires the device to go into low power mode, this pin can be overridden and controlled with SMBus registers.
Lee
Hi Naoki,
It is possible to read and write registers with nPRSNT = Low or High. When nPRSNT = High and the DS50PCI402 is in a low power mode the register will not be "reset" to default values. They will retain any values written during configuration by the customer.
Lee
