I have a customer that failed to solder the thermal pad on the subject part number to their PCB. It is not know if there is a solder pad on the PCB or not. The customer needs to know what failure modes and life expectancy the device might have if the board is put into service in this state. It is clear to them that the data sheets expressly state that the solder pad must be soldered to the PCB but they are looking for guidance on what might happen to the device if the solder pad is not connected to the PCB.
Thanks in advance for any comments you can make
Kirk Horn
Arrow Electronics
