Other Parts Discussed in Thread: SN65HVD233
I've been working on a project that requires a CAN Bus and our EEs had decided to use SN65HVD233 CAN Bus Transceivers. I had programmed our controller and had the controller codes consulted by two other embedded system engineers. They had verified correct settings however, I was not able to read the data sent by the microcontroller.
My setup is composed of a microcontroller connected to the SN65HVD233 via CAN Bus and the output of the CAN Bus is connected to a CAN Bus Analyzer which will display the data transmitted from the microcontroller over CAN bus or vice versa.
What equipment can I use to verify that the Transceiver receives and transmits data?
Kat
