Other Parts Discussed in Thread: TPD12S016
Hi Team,
customer used TPD12S016 on their IPC system, they found that the DDC signal is failed if they place a 2.2k pullup resistor on DDC terminal(per Intel reference design suggestion), however if they changed the pullup resistor to 100k, the DDC function is worked properly, they want to know why?
Also, per the product data sheet, the DDC line can work properly with no external pullup resistor, so should we need to suggest customer to remove the 100k pullup resistor even though this pullup resistor value is worked?
Please advise. Thanks.
Arthur
