Other Parts Discussed in Thread: TPS65982, TPS65982-EVM
Can i know the TPS65982 Boosterpack EVM can support Dediprog SF serious I2C Hardware Interface?
Regards:
Prasadkumar T
Regards:
Prasadkumar T
The SPI Flash IC (W25Q80) on the TPS65982-EVM (BoosterPack EVM ) can be programmed using the DediProg SF100 IC Programmer over SPI with a little blue-wiring using male-to-male jumper wires.
The SPI pins on the TPS65982-EVM are labeled SPI_CLK, SPI_MISO, SPI_MOSI, SPI_CSZ, and you will also need a connection to GND.
All of these pins are routed to headers J2 & J3.
As far as I know, the DediProg does not support I2C programming & the Flash IC used with the TPS65982 must be SPI.
Hi Brian.
Thanks for your kind response. got idea from your command.
Regards:
Prasad
