Other Parts Discussed in Thread: TUSB8020B
Dear Sir,
I have a question of TUSB8020B.
When the upstream port is connected to an electrical environment that only supports Super-speed connections, then what about the downstream ports support? Below I have put two cases. Please let me know which one is true ?
1.When Upstream is SuperSpeed USB only, then this Hub will support SuperSpeed USB connections only on the downstream ports and high-speed, full-speed/low-speed connections are disabled on the downstream ports.
2.When Upstream is SuperSpeed USB only, then this Hub will support all the SuperSpeed USB, high-speed, full-speed/low-speed connections on the downstream ports.
Thank you very much!
