Other Parts Discussed in Thread: DS250DF410
Dear e2e,
I got the DS250DF410 profiles - thank you and all seems ok.
I have the board running, locked at 25G and a nice eye out and error checker says no errors and eye monitor shows a nice open eye - so all good.
But,when I switch to PRBS generation, by turning on PRBS generator and setting the output on the CDR page to PRBS, I don't get a signal out - the output drops to about 50mVpp of 'noise' and no eye visible.
so....
I am only doing these 2 steps to get PRBS out, I must be missing a step - am I missing anything?
Once operating, would you expect the outgoing PRBS to be synchronous with the incoming data - or rather just running off the VCO inside the part and NOT sync'd with incoming data?
Finally, how close in frequency do you expect the PRBS out to be to the 25.78125 data rate, assuming it is running off the VCO and not synchronous.
Is the 25MHz clock required for PRBS but not normal operation? - or always required? - the Eval board user guide does not mention connecting up a 25MHz clock.
Thanks in advance for your help.
John French
