Other Parts Discussed in Thread: SN75DP130
When using SN75DP130 to create DP++ Dual Mode the data sheet shows a schematic (figure 24) that uses FETs to short out the coupling capacitors on the Aux channel so it can be used DC coupled for DDC. Can anyone help with choice of FETs, I'm concerned that MOSFETs with body diode will affect normal Aux operation. Are there any example schematics of this setup, the eval kit does not use this scheme.
Any help appreciated.
Julian
